作者 主題: 配置完DNS用dig测试不显示ANSWER部分  (閱讀 3154 次)
第五令燕
  • 张钦博
« 於: 2019-06-16 15:00 »
小弟正在学习搭建DNS中,但是用dig测试的时候却不显示ANSWER部分,大佬们能否帮我看下哪里出了问题。(小弟已经把防火墙关掉了)
Centos 6.x
[root@www ~]# dig master.centos.zqb
; <<>> DiG 9.8.2rc1-RedHat-9.8.2-0.68.rc1.el6_10.1 <<>> master.centos.zqb
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 52739
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;; QUESTION SECTION:
;master.centos.zqb.             IN      A
;; AUTHORITY SECTION:
.                       3600            IN      SOA     a.root-servers.net. nstld.verisign-grs.com. 2019061600 1800 900 604800 86400
;; Query time: 929 msec
;; SERVER: 192.168.0.1#53(192.168.0.1)
;; WHEN: Sun Jun 16 12:24:33 2019
;; MSG SIZE  rcvd: 110
***下面是/etc/named.conf的配置***
options {
        listen-on port 53 { any; };
        directory       "/var/named";
        dump-file       "/var/named/data/cache_dump.db";
        statistics-file "/var/named/data/named_stats.txt";
        memstatistics-file "/var/named/data/named_mem_stats.txt";
        allow-query     { any; };
        recursion yes;
        allow-transfer { none; };
        listen-on { any; };
        dnssec-enable yes;
        dnssec-validation yes;
        /* Path to ISC DLV key */
        bindkeys-file "/etc/named.iscdlv.key";
        managed-keys-directory "/var/named/dynamic";
logging {
        channel default_debug {
                file "data/named.run";
                severity dynamic;
zone "." IN {
        type hint;
        file "named.ca";
zone "centos.zqb" IN {
        type master;
        file"named.centos.zqb";
zone "0.168.192.in-addr.arpa" IN {
        type master;
        file"named.192.168.0";
***下面是/var/named/named.centos.zqb的配置***
$TTL    600
@                                IN SOA          master.centos.zqb. zqb.www.centos.zqb. 2019061600 3H 15M 1W 1D
@                                IN NS           master.centos.zqb.
master.centos.zqb.     IN A            192.168.0.103
www.centos.zqb.        IN A            192.168.0.103
linux.centos.zqb.         IN A            192.168.0.103
slave.centos.zqb.        IN A            192.168.0.107
« 上次編輯: 2019-06-16 15:14 由 第五令燕 »
Re: 配置完DNS用dig测试不显示ANSWER部分
« 回覆 #1 於: 2019-06-17 20:09 »
先看看 log :
grep named /var/log/messages
