作者 主題: FreeBSD mmap on CIFS share....  (閱讀 4963 次)
cmwang
  • 文章數: 328
« 於: 2016-09-09 19:58 »
鵝公司的產品因為是based on FreeBSD這個不算太熱門的OS上,而RD說讀寫檔案因為效能考量是以mmap方式處理,之前都是要user提供NFS的storage(CIFS的話只知道因為歷史因素不建議用,但為啥不能用沒人說得出所以然 :P),最近因為user強力要求要配合CIFS storage,鵝只好拿FreeBSD去mount CIFS share,然後用iozone指定以mmap方式測試,結果果然是不work,不過讓鵝大惑不解的是iozone讀寫CIFS/NFS的方式都一樣,為啥上方的CIFS會在gettimeofday這個看似和filesystem扯不上邊的動作後產生SIGSEGV而被kill掉,但下方的NFS則一切正常啊 ??? ???....
不要,不要,我不要這種顏色的帽子 ;D ;D....
Re: FreeBSD mmap on CIFS share....
« 回覆 #1 於: 2016-09-10 15:42 »
freenas 好像是用 freebsd 做的...
cmwang
  • 文章數: 328
« 回覆 #2 於: 2016-09-19 18:02 »
鵝後來找到Subject: Re: ports/29704: Imagemagick Identify utility crashes when used on smbfs mounted share....
Yes, this is an expected behavior - smbfs uses a counter to track open/close operations and if it became zero, an SMB "close" request sent to server. Obviously, mmap() doesn't give additional VOP_OPEN() call and file is really closed after close(), so any subsequent read/write operation will fail.
In the DOS/Windows world it is normal to have strong relation between open/close operations, while VOP_OPEN()/VOP_CLOSE() in FreeBSD do not match sometime (I'm suspect that it is possible to remove inconsistence, though).
One of the possible solutions is to remove smb_close request from smbfs_close() vop and leave it only in the smbfs_inactive(), but this will not allow programs to immediately release a file by just closing it.
看來是FreeBSD對VOP_OPEN/VOP_CLOSE的解釋造成的,難怪從十幾年前就是這樣了 :P :P....
