作者 主題: may result in undefined or erroneous behavior  (閱讀 4192 次)
tonyvan123
  • 文章數: 447
« 於: 2016-05-26 15:37 »
環境 FreeBSD 10 + Apach24 + php56 +openssl-1.0.2_12
1. 在apache24 啟動時即出現以下錯誤
[Thu May 26 15:25:33.864096 2016] [ssl:warn] [pid 11128] AH01882: Init: this version of mod_ssl was compiled against a newer library (OpenSSL 1.0.1l-freebsd 15 Jan 2015, version cu
rrently loaded is OpenSSL 1.0.1j-freebsd 15 Oct 2014) - may result in undefined or erroneous behavior
2. 突然出現以下錯誤,造成無法連線,以ssh連線至主機看apache24,apache的service連活著,重新啟動apache24即恢復正常
May 26 09:17:05 www kernel: pid 1449 (httpd), uid 1002: exited on signal 11
3. 突然出現以下錯誤,造成無法連線,,以ssh連線至主機看apache24,apache的service連活著,重新啟動apache24即恢復正常
May 20 13:36:20 www kernel: sonewconn: pcb 0xfffff800322e8498: Listen queue overflow: 193 already in queue awaiting acceptance (222 occurrences)
tonyvan123
  • 文章數: 447
Re: may result in undefined or erroneous behavior
« 回覆 #1 於: 2016-06-13 17:37 »
問題已解決,但改的事項滿多的,要安裝package,要改參數
