作者 主題: [LDAP PDC] Building a SAMBA PDC on Centos 7 with smbldap-tools  (閱讀 8403 次)
Ref:
http://www.server-world.info/en/note?os=CentOS_7&p=openldap&f=1
http://www.server-world.info/en/note?os=CentOS_7&p=openldap&f=3
http://www.server-world.info/en/note?os=CentOS_7&p=openldap&f=4
http://www.server-world.info/en/note?os=CentOS_6&p=samba&f=4
http://www.study-area.org/tips/smbldap/
https://wiki.samba.org/index.php/Required_settings_for_NT4-style_domains
### Configure LDAP Server ###
yum -y install openldap-servers openldap-clients
cp /usr/share/openldap-servers/DB_CONFIG.example /var/lib/ldap/DB_CONFIG
chown ldap. /var/lib/ldap/DB_CONFIG
systemctl start slapd
systemctl enable slapd
slappasswd # copy the result
mkdir /root/tmp
cd /root/tmp
vi chrootpw.ldif
dn: olcDatabase={0}config,cn=config
changetype: modify
add: olcRootPW
olcRootPW: {SSHA}xxxxxxxxxxxxxxxxxxxxxxxx
ldapadd -Y EXTERNAL -H ldapi:/// -f chrootpw.ldif
for i in /etc/openldap/schema/*.ldif; do ldapadd -Y EXTERNAL -H ldapi:/// -f $i ; done
vi chdomain.ldif
dn: olcDatabase={1}monitor,cn=config
changetype: modify
replace: olcAccess
olcAccess: {0}to * by dn.base="gidNumber=0+uidNumber=0,cn=peercred,cn=external,cn=auth"
  read by dn.base="cn=Manager,dc=example,dc=com" read by * none
dn: olcDatabase={2}hdb,cn=config
changetype: modify
replace: olcSuffix
olcSuffix: dc=example,dc=com
changetype: modify
replace: olcRootDN
olcRootDN: cn=Manager,dc=example,dc=com
changetype: modify
add: olcRootPW
changetype: modify
add: olcAccess
olcAccess: {0}to attrs=userPassword,shadowLastChange by
  dn="cn=Manager,dc=example,dc=com" write by anonymous auth by self write by * none
olcAccess: {1}to dn.base="" by * read
olcAccess: {2}to * by dn="cn=Manager,dc=example,dc=com" write by * read
ldapmodify -Y EXTERNAL -H ldapi:/// -f chdomain.ldif
vi basedomain.ldif
dn: dc=example,dc=com
objectClass: top
objectClass: dcObject
objectclass: organization
o: Example dot Com
dc: Example
dn: cn=Manager,dc=example,dc=com
objectClass: organizationalRole
cn: Manager
description: Directory Manager
dn: ou=People,dc=example,dc=com
objectClass: organizationalUnit
ou: People
dn: ou=Group,dc=example,dc=com
ou: Group
ldapadd -x -D cn=Manager,dc=example,dc=com -W -f basedomain.ldif
#-- skip this part if you don't want TLS --#
# you MUST build your server key and cert first, the 'easy-ras' package should be a good idea
# Assuming you've installed openvpn and easy-rsa
cd /etc/openvpn/easy-rsa
cp ldap.example.com.key ldap.example.com.crt ca.crt /etc/openldap/certs/
cd /etc/openldap/certs/
chown ldap. ldap.example.com.* ca.crt
cd /root/tmp
vi mod_ssl.ldif
dn: cn=config
changetype: modify
add: olcTLSCACertificateFile
olcTLSCACertificateFile: /etc/openldap/certs/ca.crt
replace: olcTLSCertificateFile
olcTLSCertificateFile: /etc/openldap/certs/ldap.example.com.crt
replace: olcTLSCertificateKeyFile
olcTLSCertificateKeyFile: /etc/openldap/certs/ldap.example.com.key
ldapmodify -Y EXTERNAL -H ldapi:/// -f mod_ssl.ldif
vi /etc/sysconfig/slapd
SLAPD_URLS="ldapi:/// ldap:/// ldaps:///"#-- end of TLS configuration --#
### Configure Client ###
#-- without TLS --#
yum -y install openldap-clients nss-pam-ldapd
authconfig --enableldap --enableldapauth --ldapserver=dlp.server.world --ldapbasedn="dc=example,dc=com" --enablemkhomedir --update
systemctl restart nslcd
systemctl enable nslcd
#-- withTLS --#
echo "TLS_REQCERT allow" >> /etc/openldap/ldap.conf
echo "tls_reqcert allow" >> /etc/nslcd.conf
scp ldap.example.com:/etc/openldap/certs/cacert.pem /etc/openldap/cacerts
authconfig --enableldap --enableldapauth --enableldaptls --ldapserver=dlp.server.world --ldapbasedn="dc=example,dc=com" --enablemkhomedir --update
### Configure SAMBA ###
yum -y install samba samba-client
cp /usr/share/doc/samba-4.2.3/LDAP/samba.ldif /etc/openldap/schema/
ldapadd -Y EXTERNAL -H ldapi:/// -f /etc/openldap/schema/samba.ldif
vi samba_indexes.ldif
changetype: modify
add: olcDbIndex
olcDbIndex: uidNumber eq
olcDbIndex: gidNumber eq
olcDbIndex: loginShell eq
olcDbIndex: uid eq,pres,sub
olcDbIndex: memberUid eq,pres,sub
olcDbIndex: uniqueMember eq,pres
olcDbIndex: sambaSID eq
olcDbIndex: sambaPrimaryGroupSID eq
olcDbIndex: sambaGroupType eq
olcDbIndex: sambaSIDList eq
olcDbIndex: sambaDomainName eq
olcDbIndex: default sub
ldapmodify -Y EXTERNAL -H ldapi:/// -f samba_indexes.ldif
systemctl restart slapd
### Configure openldap-tools ###
rpm -Uvh http://dl.fedoraproject.org/pub/epel/7/x86_64/e/epel-release-7-5.noarch.rpm
yum install -y install smbldap-tools
cd /etc/samba
mv smb.conf smb.conf.bak
cp /usr/share/doc/smbldap-tools-*/smb.conf smb.conf
vi /etc/samba/smb.conf
[global]
workgroup = EXAMPLE
netbios name = ldap
deadtime = 10
log level = 1
log file = /var/log/samba/log.%m
max log size = 5000
debug pid = yes
debug uid = yes
syslog = 0
utmp = yes
security = user
domain logons = yes
os level = 64
logon path =
logon home =
logon drive =
logon script =
passdb backend = ldapsam:"ldap://ldap.example.com/"
ldap ssl = no
ldap admin dn = cn=Manager,dc=example,dc=com
ldap delete dn = no
ldap password sync = yes
ldap suffix = dc=example,dc=com
ldap user suffix = ou=People
ldap group suffix = ou=Group
ldap machine suffix = ou=Computers
ldap idmap suffix = ou=Idmap
add user script = /usr/sbin/smbldap-useradd -m '%u' -t 1
rename user script = /usr/sbin/smbldap-usermod -r '%unew' '%uold'
delete user script = /usr/sbin/smbldap-userdel '%u'
set primary group script = /usr/sbin/smbldap-usermod -g '%g' '%u'
add group script = /usr/sbin/smbldap-groupadd -p '%g'
delete group script = /usr/sbin/smbldap-groupdel '%g'
add user to group script = /usr/sbin/smbldap-groupmod -m '%u' '%g'
delete user from group script = /usr/sbin/smbldap-groupmod -x '%u' '%g'
add machine script = /usr/sbin/smbldap-useradd -w '%u' -t 1
admin users = domainadmin
[NETLOGON]
path = /var/lib/samba/netlogon
browseable = no
share modes = no
[PROFILES]
path = /var/lib/samba/profiles
browseable = no
writeable = yes
create mask = 0611
directory mask = 0700
profile acls = yes
csc policy = disable
map system = yes
map hidden = yes
[homes]
comment = Home Directories
browseable = no
writable = yes
mkdir /var/lib/samba/{netlogon,profiles}
smbpasswd -W    # type the passwor of ldap manager twice
system start nmb
system start smb
system enable nmb
system enable smb
smbldap-config
    # Answer all the question down to the way
    # You could however press ctrl-c and reload the command if you made a mistake
smbldap-populate
smbldap-groupadd -a domainadmin
smbldap-useradd -am -g domainadmin domainadmin
smbldap-passwd domainadmin
### To add a Win7 client ###
smbldap-useradd -W win7pchttps://wiki.samba.org/index.php/Required_settings_for_NT4-style_domains
### Win7 modification ###
# Edit a text file named 'sambafix.reg'
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanManWorkstation\Parameters]
"DomainCompatibilityMode"=dword:00000001
"DNSNameResolutionRequired"=dword:00000000
# Double click the file to import the registry
# Reboot and join the 'EXAMPLE' domain using domainadmin or root account
« 上次編輯: 2017-09-11 23:00 由 netman »
