作者 主題: 請問ExcelWriterXML如何寫入中文  (閱讀 5010 次)
tonyvan123
  • 文章數: 447
« 於: 2015-10-27 17:38 »
經過1個星期的測試,中文問題仍無解
tonyvan123
  • 文章數: 447
程式碼如下
« 回覆 #1 於: 2015-10-28 11:33 »
<?php
 * Example page for how to use the Excel Writer XML
 * @package ExcelWriterXML
 * @subpackage examples
 * @filesource
 * Include the required Class file
include('ExcelWriterXML.php');
 * @source
$xml = new ExcelWriterXML;
$xml->docAuthor('Robert F Greer');
$xml->overwriteFile(true);
$iHeaderFormat1 = $xml->addStyle('StyleHeader');
$iHeaderFormat1->alignHorizontal("Left");
$iHeaderFormat1->alignVertical("Center");
$iTextFormat1 = $xml->addStyle('Text1');
$iTextFormat1->alignHorizontal("Left");
$iTextFormat1->alignVertical("Center");
$iNUMFormat1 = $xml->addStyle('Number1');
$iNUMFormat1->alignHorizontal("Right");
$iNUMFormat1->alignVertical("Center");
$iNUMFormat1->numberFormat('#,##0.00');
$iDateFormat1 = $xml->addStyle("DateFormat1");
$iDateFormat1->alignHorizontal("Left");
$iDateFormat1->alignVertical("Center");
$iDateFormat1->numberFormatDatetime('yyyy/mm/ddThh:mm:ss');
$sheet1 = $xml->addSheet('My Sheet');
$sheet1->writeString(1,1,'標題一','StyleHeader');
$sheet1->writeString(1,2,'Number','StyleHeader');
$sheet1->writeString(1,3,'DateTime','StyleHeader');
$sheet1->writeString(2,1,'Test String','Text1');
$sheet1->writeNumber(2,2,1234.32,'Number1');
$sheet1->writeDateTime(2,3,'2015/10/23 11:52:12','DateFormat1');
$xml->sendHeaders();
$xml->writeData('MyFile1.xml');
tonyvan123
  • 文章數: 447
Re: 請問ExcelWriterXML如何寫入中文
« 回覆 #2 於: 2015-10-28 17:18 »
自己解答
把 ExcelWriterXML.php中的xml head 改掉即可
修改前$xml = '<?xml version="1.0"  ?>'
修改後$xml = '<?xml version="1.0"  encoding="BIG5" ?>'
