作者 主題: [config]check CPU temperature on rpitc2  (閱讀 4096 次)
« 於: 2015-06-03 11:55 »
the rpitc2 seems not implemented with vcgencmd command
to enable this:
apt-get install ca-certificates git-core binutils
apt-get update
apt-get install binutils
wget https://raw.github.com/Hexxeh/rpi-update/master/rpi-update
cp rpi-update /usr/local/bin/
chmod +x /usr/local/bin/rpi-updat
rpi-update
reboot
then run:
sudo /opt/vc/bin/vcgencmd measure_temp
« 上次編輯: 2015-06-03 11:57 由 netman »
