作者 主題: 請問如何將iFrame放進table的td中而之後的td資料仍會顯示  (閱讀 5213 次)
tonyvan123
  • 文章數: 447
1. 主程式
<!DOCTYPE html>
<html>
<head>
<title> 主頁 </title>
   <meta http-equiv="Content-Language" content="zh-tw">
   <meta http-equiv="content-type" content="text/html; charset=big5">
   <meta http-equiv="refresh" content="1200;url=https://www.synvision.com.tw/SonyMobile/reload.php">
   <style type="text/css">
      header, nav, section, article, footer {
         display: block;
        color: white;
      header, footer {
        text-align: center;
        width: 100%;
      header {
        background-color: red;
        font-size: 36px;
        font-weight: bold;
      nav {
        display:inline-block;
        top: 50px;
        left: 8px;
        width: 160px;
        white-space:nowrap;
        background-color: #FFFFBB;
      nav ul {
         margin: 0 auto;
         width: 100%;
         list-style-type: disc;
         list-style: outside;
         display: inline;
         white-space:wrap;
      nav ul li {
         position: left;
         white-space:wrap;
         color=blue;
      section {
         width: 100%;
         background-color: none;
         padding: 20px;
         margin: 20px;
      footer {
         background-color: green;
         font-size: 10px;
      iframe:focus {
         outline: none;
      iframe[seamless] {
         display: block;
   </style>
   <SCRIPT Language="JavaScript">
     function LoadFunction(aID) {
       var iFUN=document.getElementById(aID.id);
       var iPRG=document.getElementById("src1");
       if (iFUN.id=="RMA_Request") {
          iPRG.src="RMA_request.php";
          iPRG.width="1000";
          iPRG.height="1800";
       } else if (iFUN.id=="RMA_modify") {
           iPRG.src="RMA_modify.php";
       } else if (iFUN.id=="RMA_unfinished") {
           iPRG.src="RMA_unfinished.php";
       } else if (iFUN.id=="RMA_Query") {
           iPRG.src="RMA_Query.php";
       } else if (iFUN.id=="RMA_Shipping") {
           iPRG.src="RMA_Shipping.php";
       } else {
          iPRG.src="ReLogin.php";
      function showtime24H(){
         var msg="";
         var now = new Date();
         var years = now.getYear()+1900;
         var months = now.getMonth()+1;
         var days = now.getDate();
         var hours = now.getHours();
         var minutes = now.getMinutes();
         var seconds = now.getSeconds();
         var timeValue = years ;
         timeValue += ((months < 10) ? ":0" : ":") + months;
         timeValue += ((days < 10) ? ":0" : ":") + days;
         timeValue += "-";
         timeValue += ((hours < 10) ? ":0" : ":") + hours;
         timeValue += ((minutes < 10) ? ":0" : ":") + minutes;
         timeValue += ((seconds < 10) ? ":0" : ":") + seconds;
         txtMSG=document.getElementById("txtMSG");
         txtMSG.value = msg+timeValue;
         timerID = setTimeout("showtime24H()",1000);
         timerRunning = true;
   </script>
</head>
<body OnLoad="showtime24H();">
<header>
   <table border=0 width="100%">
   <tr>
      <td align="center" widht="80%">主頁</td>
      <td align="right"><input type=text name=txtMSG id=txtMSG size=16 disabled="disabled"></td>
   </tr>
   </table>
</header>
<nav>
   <ul>
            <li><a href="#" onClick="LoadFunction(this);" id="RMA_Request">申請</a></li>
            <li><a href="#" onClick="LoadFunction(this);" id="RMA_modify">申請修改</a></li>
            <li><a href="#" onClick="LoadFunction(this);" id="RMA_unfinished">未結案</a></li>
            <li><a href="#" onClick="LoadFunction(this);" id="RMA_Query">查詢</a></li>
            <li><a href="#" onClick="LoadFunction(this);" id="RMA_Shipping">出貨查詢</a></li>
            <li><a href="#" onClick="LoadFunction(this);" id="ReLogin">重新登入</a></li>
   </ul>
</nav>
<section>
   <article>
      <div align="left" style="position: absolute; top: 60px; left: 190px; width: 1110px; height: 1210px;" >
         <iframe name="src1" id="src1" frameborder="0" width="1100" height="1200" sandbox="allow-forms allow-scripts" src="ReLogin.php">
         </iframe>
      </div>
   </article>
</section>
<footer>
</footer>
</body>
</html>
tonyvan123
  • 文章數: 447
2. 頁中程式
                           <!DOCTYPE html>
<Html>
<Head>
<Title>RAM登錄</Title>
<meta http-equiv="Content-Type" content="text/html; charset=big5">
  a:hover {  color: #FF0000; text-decoration: none}
  a:visited {  text-decoration: none}
  a:link {  color: #0000FF; text-decoration: none}
  a:active {  text-decoration: none}
  textarea { height: auto; }
   input.right{
      text-align:right;
</style>
<script language="JavaScript">
  var errfound = false;
  var xmlHttp;
   function ValidateNumber(e) {
       var key;
       if(window.event) {
           key = e.keyCode;
       }else if(e.which) {
           key = e.which;
       } else {
           return true;
       if(8==key || 46==key){//8:backspace 46:delete (倒退鍵和刪除鍵也允許作用)
           return true;
       var keychar = String.fromCharCode(key);
       var reg = /\d/;
       return reg.test(keychar);
  function FieldLength(item,len) {
    if (item.value.length > len - 1 ) return false;
     else return true;
  function ValidLength(item, len) {
      return (item.length >= len);
  function MatchLength(item, len) {
      document.frmMobile.msg.value = item.length;
      return (item.length == len);
  function ShowMsg(elem, text){
      window.alert(text);
      elem.select();
      elem.focus();
      errfound = true;
  function IsNull( val ) {
     var isValid = false;
     if (val+"" == "null")
        isValid = true;
     return isValid;
  function IsUndef( val ) {
     if (val+"" == "undefined")
        isValid = true;
     return isValid;
  function IsBlank( str ) {
     if ( IsNull(str) || IsUndef(str) || (str+"" == "") )
        isValid = true;
     return isValid;
  function IsAlpha( str ) {
     if (str+"" == "undefined" || str+"" == "null" || str+"" == "")
        return false;
     var isValid = true;
     str += "";
     for (i = 0; i < str.length; i++) {
        if ( !( ((str.charAt(i) >= "a") && (str.charAt(i) <= "z")) ||
           ((str.charAt(i) >= "A") && (str.charAt(i) <= "Z")) ) ) {
                 isValid = false;
                 break;
     return isValid;
  function IsAlphaNum( str ) {
        return false;
     var isValid = true;
     str += "";
     if (!(((str.charAt(i) >= "0") && (str.charAt(i) <= "9")) ||
           ((str.charAt(i) >= "A") && (str.charAt(i) <= "Z"))))
              isValid = false;
              break;
     return isValid;
  function IsValidEmail( str ) {
        return false;
     var isValid = true;
     str += "";
     namestr = str.substring(0, str.indexOf("@"));
     domainstr = str.substring(str.indexOf("@")+1, str.length);
     if (IsBlank(str) || (namestr.length == 0) ||
           (domainstr.indexOf(".") <= 0) ||
           (domainstr.indexOf("@") != -1) ||
           !IsAlpha(str.charAt(str.length-1)))
        isValid = false;
     return isValid;
   function jsGetDPY(iPtype) {
      var selectedValue = iPtype.options[iPtype.selectedIndex].value;
      var iPRG=document.getElementById("SetDPY");
      //document.frmMobile.query.value="SetDPY";
      iPRG.src="CompanySetDPY1.php"+"?MODE="+selectedValue;
  function jsSetProductMode(iPtype)
      var DocRoot=document.getElementById("DocRoot");
      document.frmMobile.query.value="SetMode";
      window.location.href = DocRoot.value+"/Company/CompanySetModeDPY.php"+"?iKIND="+selectedValue;
   function jsSubmit()
      var num=document.frmMobile.quantity.value;
      if ( num < 1 ) {
         errfound = true;
         ShowMsg(document.frmMobile.quantity, '數量不能小於 1 !');
      if (errfound==true) {
         document.frmMobile.query.value="error-found";
      } else {
         document.frmMobile.query.value="submit";
   function AlertMsg()
      var ipar = window.parent;
      var msg1="送修時請勿將機卡、機卡托盤、附配件一起送修\n";
      var msg2="若需附上配件一起檢測時,請在備註欄位加註說明\n";
      var msg3="Model ZR (NNN)機種,送修時請將背蓋一起送修\n";
      window.alert(msg1+msg2+msg3);
   function Validate()
</script>
</Head>
<body bgcolor="#ffffff" OnLoad="AlertMsg();">
   <form onSubmit="return Validate();" method="post" name="frmMobile" target="_self" id="frmMobile" width="100%">
     <table width="100%" border="0" name="mainTable" id="mainTable">
        <tr>
           <td width="16%" height="14">&nbsp;</td>
           <td height="14" bgcolor="#ffffff">
              <div align="center"><IMG height=22  width=106 src=https://www.synvision.com.tw/agent/callfix/images/service_regist_title.gif ><br>
              </div>
               <hr>
              <center>
                 <font color="#400080" size="2"><font color="#ff0000"></font></font> <font color="#400080" size="2">:
                 </font>
              </center>
           </td>
           <td width="15%" height="14px">
           </td>
        </tr>
        <tr>
           <td width="16%" height="286"> </td>
           <td height="286" bgcolor="#004080">
              <table width="100%" border="0" height="257" align="center">
                 <tr>
                    <td width="30%" height="30px" bgcolor="#99cccc" align="right"><font face="新細明體" size="2" color="#333333">
                      商品名稱:</font>
                    </td>
                    <td width="68%" height="30px" bgcolor="#cccccc">
                       <select id="ProductKind" name="ProductKind" STYLE='BACKGROUND-COLOR:#44FFFF' onChange='javascript: jsSetProductMode(this)'>
                          <option value=DPA(單機) selected='selected'>DPA(單機)</option>  <option value=DOA>DOA</option>  <option value=機板>機板</option>  <option value=配件>配件</option>  <option value=藍芽>藍芽</option>                       </select>
                       <font size="2" color="#ff0000">*</font>
                     </td>
                 </tr>
                 <tr>
                   <td width="30%" height="30px" bgcolor="#99cccc" align="right"><font face="新細明體" size="2" color="#333333">機型:</font></td>
                       <select name="ProductMode" id="ProductMode" STYLE="BACKGROUND-COLOR:#FFFFFF"  onChange='javascript: jsGetDPY(this) ;'>
                         <option value=N1 selected='selected'>N1</option>  <option value=N2>N2</option>  </select>
                     </td>
                 </tr>
                 <tr>
                    <td width="30%" height="30px" bgcolor="#99cccc" align="right"><font face="新細明體" size="2" color="#333333">DPY No:</font></td>
                       <div width="68%" height="30px">
                                <iframe name="SetDPY" id="SetDPY" vspace="50%" style="width:50%; height:50%; display:box;" frameborder="0" sandbox="allow-forms
                                   allow-scripts allow-top-navigation" scrolling=no src="CompanySetDPY1.php" ?MODE=N1 >
                       </div>
                     </td>
                 </tr>
                 <tr>
                   <td width="30%" height="30px" bgcolor="#99cccc" align="right"><font face="新細明體" size="2" color="#333333">數量:</font></td>
                        <input class="right" type="text" name="quantity" id="quantity" maxlength="3" size="3" style="ime-mode:disabled" onkeypress="return ValidateNumber(event)"
                            value=>
                     </td>
                 </tr>
              </table>
              <table name="tabMSG" id="tabMSG">
                 <tr><td>
                    <input type="submit" value="新  增" name="submit" onclick="javascript: jsSubmit();">
                     <input type="hidden" name="query" id="query" value="">
                     <input type="hidden" name="DocRoot" id="DocRoot" value="https://www.synvision.com.tw">
                     <input type="test" name="txtMEMO" id="txtMEMO" value="">
                 </td></tr>
                 <tr><td>
                    訊息::MSG=,KIND:DPA(單機)
                 </td></tr>
              </table>
           </td>
        </tr>
     </table>
  </form>
   <div align="left" style="position: absolute; top: 120;left: 100px;width: 210px;height: 125px;" >
      <iframe name="list1" id="list1" frameborder="0" width="900" height="800" sandbox="allow-forms allow-scripts" src="RMA_request_list.php">
      </iframe>
   </div>
</body>
</html>
tonyvan123
  • 文章數: 447
3. 第3支程式
<!DOCTYPE html>
<Html>
<Head>
<Title>RAM登錄 Set DPY</Title>
</Head>
<body>
      <select name='DPY' width='180px' STYLE='BACKGROUND-COLOR: #FFFFFF'   >  <option value=2233-黑色 selected='selected'>2233-黑色</option>  <option value=3366-白色>3366-白色</option></select></body>
</html>
tonyvan123
  • 文章數: 447
此為整個頁面
問題在 iframe name="SetDPY"  之後還有一個 td 用以輸入 數量 不會顯示
tonyvan123
  • 文章數: 447
自問自答,是少了一個 </iframe>
找到了也氣死了,浪費了我8個工作小時
