作者 主題: Run AVD出現Unfortunately, XXX has stopped.  (閱讀 6057 次)
moon1029
« 於: 2012-08-30 13:53 »
請問一下,我在Run AVD時,出現Unfortunately, XXX has stopped.後便停止,error message:
08-30 09:37:48.159: D/dalvikvm(632): GC_FOR_ALLOC freed 119K, 3% free 8163K/8391K, paused 69ms, total 77ms
08-30 09:37:48.589: D/gralloc_goldfish(632): Emulator without GPU emulation detected.
08-30 09:37:51.279: I/System.out(632): APP not found!
08-30 09:37:51.279: D/AndroidRuntime(632): Shutting down VM
08-30 09:37:51.289: W/dalvikvm(632): threadid=1: thread exiting with uncaught exception (group=0x40a13300)
08-30 09:37:51.319: E/AndroidRuntime(632): FATAL EXCEPTION: main
08-30 09:37:51.319: E/AndroidRuntime(632): java.lang.NullPointerException
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.app.Instrumentation.execStartActivity(Instrumentation.java:1409)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.app.Activity.startActivityForResult(Activity.java:3351)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.app.Activity.startActivityForResult(Activity.java:3312)
08-30 09:37:51.319: E/AndroidRuntime(632):    at joanne.lin.MainActivity$1.onClick(MainActivity.java:43)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.view.View.performClick(View.java:4084)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.view.View$PerformClick.run(View.java:16966)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.os.Handler.handleCallback(Handler.java:615)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.os.Handler.dispatchMessage(Handler.java:92)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.os.Looper.loop(Looper.java:137)
08-30 09:37:51.319: E/AndroidRuntime(632):    at android.app.ActivityThread.main(ActivityThread.java:4745)
08-30 09:37:51.319: E/AndroidRuntime(632):    at java.lang.reflect.Method.invokeNative(Native Method)
08-30 09:37:51.319: E/AndroidRuntime(632):    at java.lang.reflect.Method.invoke(Method.java:511)
08-30 09:37:51.319: E/AndroidRuntime(632):    at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:786)
08-30 09:37:51.319: E/AndroidRuntime(632):    at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
08-30 09:37:51.319: E/AndroidRuntime(632):    at dalvik.system.NativeStart.main(Native Method)
找很久答案,覺得應疑似為Activity的問題,但確切問題為何實在看不出來,所以想請問是否有人了解 這message指的意思是什麼?
錯誤是在何處?謝謝!
