作者 主題: 求教 !! 安裝/usr/ports/lang/php52-extensions失敗  (閱讀 6611 次)
weiyi
  • 文章數: 15
checking for dlopen... yes
checking for posix_memalign... yes
checking pkg-config files for X11 are available... yes
checking for LIBDRM... yes
checking for DRI2PROTO... yes
checking for DRIGL... yes
checking expat.h usability... yes
checking expat.h presence... yes
checking for expat.h... yes
checking for XML_ParserCreate in -lexpat... yes
configure: creating ./config.status
config.status: creating configs/autoconf
config.status: executing configs commands
configure: WARNING: unrecognized options: --disable-gallium
        prefix:          /usr/local
        exec_prefix:     ${prefix}
        libdir:          ${exec_prefix}/lib
        includedir:      ${prefix}/include
        Driver:          dri
        OSMesa:          no
        DRI drivers:     i810 i915 i965 mach64 mga r128 r200 r300 radeon tdfx unichrome savage sis swrast
        DRI driver dir:  ${libdir}/dri
        Use XCB:         yes
        Shared libs:     yes
        Static libs:     no
        GLU:             no
        GLw:             no (Motif: no)
        glut:            no
        Demos:           no
        CFLAGS:          -O2 -pipe -fno-strict-aliasing -Wall -Wmissing-prototypes -std=c99 -ffast-math -fno-strict-aliasing -fPIC
        CXXFLAGS:        -O2 -pipe -fno-strict-aliasing -Wall -fno-strict-aliasing -ansi -pedantic -fPIC
        Macros:          -DHAVE_POSIX_MEMALIGN -DUSE_XCB -DPTHREADS -DUSE_EXTERNAL_DXTN_LIB=1 -DIN_DRI_DRIVER -DHAVE_ALIAS -DGLX_INDIRECT_RENDERING -DGLX_DIRECT_RENDERING -DUSE_X86_ASM -DUSE_MMX_ASM -DUSE_3DNOW_ASM -DUSE_SSE_ASM
        Run 'gmake' to build Mesa
===>  Building for dri-7.4.4,2
Please choose a configuration from the following list:
aix
aix-64
aix-64-static
aix-gcc
aix-static
beos
bluegene-osmesa
bluegene-xlc-osmesa
catamount-osmesa-pgi
config.mgw
darwin
darwin-fat-32bit
darwin-fat-all
freebsd
freebsd-dri
freebsd-dri-amd64
freebsd-dri-x86
hpux10
hpux10-gcc
hpux10-static
hpux11-32
hpux11-32-static
hpux11-32-static-nothreads
hpux11-64
hpux11-64-static
hpux11-ia64
hpux11-ia64-static
hpux9
hpux9-gcc
irix6-64
irix6-64-static
irix6-n32
irix6-n32-static
irix6-o32
irix6-o32-static
linux
linux-alpha
linux-alpha-static
linux-debug
linux-directfb
linux-dri
linux-dri-debug
linux-dri-ppc
linux-dri-x86
linux-dri-x86-64
linux-dri-xcb
linux-fbdev
linux-glide
linux-ia64-icc
linux-ia64-icc-static
linux-icc
linux-icc-static
linux-indirect
linux-osmesa
linux-osmesa16
linux-osmesa16-static
linux-osmesa32
linux-ppc
linux-ppc-static
linux-profile
linux-solo
linux-solo-ia64
linux-solo-x86
linux-sparc
linux-sparc5
linux-static
linux-ultrasparc
linux-x86
linux-x86-32
linux-x86-64
linux-x86-64-debug
linux-x86-64-static
linux-x86-debug
linux-x86-glide
linux-x86-static
netbsd
openbsd
osf1
osf1-static
solaris-x86
solaris-x86-gcc
solaris-x86-gcc-static
sunos4
sunos4-gcc
sunos4-static
sunos5
sunos5-64-gcc
sunos5-gcc
sunos5-smp
sunos5-v8
sunos5-v8-static
sunos5-v9
sunos5-v9-cc-g++
sunos5-v9-static
ultrix-gcc
Then type 'make <config>' (ex: 'make linux-x86')
Or, run './configure' then 'make'
See './configure --help' for details
(ignore the following error message)
gmake: *** [configs/current] Error 1
*** Error code 1
Stop in /usr/ports/graphics/dri.
*** Error code 1
Stop in /usr/ports/x11-servers/xorg-vfbserver.
*** Error code 1
Stop in /usr/ports/accessibility/accerciser.
*** Error code 1
Stop in /usr/ports/accessibility.
*** Error code 1
Stop in /usr/ports.
*** Error code 1
Stop in /usr/ports/lang/php52-extensions.
*** Error code 1
192#
192# pwd
tzongyeu
  • 文章數: 4
    • PGX : Face The World
Re: 求教 !! 安裝/usr/ports/lang/php52-extensions失敗
« 回覆 #1 於: 2012-05-20 23:48 »
問題是出在因為相依性而安裝XOrg
你安裝選項選了哪些東西?
ced_free
  • 文章數: 20
« 回覆 #2 於: 2012-06-04 17:47 »
安裝的時候不要選你不知道的套件
利用以下步驟重新安裝一次吧
# cd /usr/ports/lang/php5-extensions
# make rmconfig deinstall
# make install clean
weiyi
  • 文章數: 15
« 回覆 #3 於: 2019-07-18 15:27 »
感謝指導
回覆較遲請見諒
