作者 主題: RHCE考過後,最想要的東西..  (閱讀 20674 次)
fallloveinmy
  • 文章數: 4
RHCE考過後,最想要的東西..
« 於: 2010-12-06 23:14 »
終於在12月6號
Dear XXXXXXXXX:
The results of your RHCE Certification Exam are reported below.  The
RHCE Certification Exam allows candidates to qualify for the
Red Hat Certified Engineer (RHCE) and Red Hat Certified Technician
(RHCT) certificates.  Please note that the RHCE designation is
understood to both include and supersede the RHCT designation.
RHCE requirements: score of 70 or higher on RHCT components (100 points)
                  score of 70 or higher on RHCE components (100 points)
RHCT requirement:  score of 70 or higher on RHCT components (100 points)
RHCT components score:                             85.0
RHCE components score:                             100.0
RHCE Certification:                                PASS
Congratulations -- you are now certified as a Red Hat Certified
Engineer!  Your RHCE Certificate number is XXXXXXXXXXXXXXX.
The attached file is your personal print-ready certificate.
You are entitled to print this document and use it to demonstrate
that you are an RHCE, provided you remain an RHCE in good standing.
You may not modify or change the document's contents in any way, nor
may you appropriate any elements of this document for use in other
electronic documents or printed materials.  You may only print the
document in its entirety.  Any other use of the document must be
approved by Red Hat, Inc.
Your RHCE number should be available for verification at Red Hat
Certification Central:
https://www.redhat.com/wapps/training/certification/verify.html?certNumber=XXXXXXXXXXXXXXXX
You can verify the certificates of other RHCEs and RHCTs at
https://www.redhat.com/training/certification/verify
Please visit RHCE Connection, our web site exclusively for RHCEs:
There you will find special offers from Red Hat, logo art, forums, job
listings, and more.  You can also use the site to manage your contact
information.  In order to access the site, you will need a PIN number.
You can have the PIN sent to the email address we have on file at
https://www.redhat.com/training/certification/lostpin.html
If you wish to connect to the forums directly:
https://certforums.redhat.com
Certification in Red Hat Enterprise Linux opens up new opportunities.
We hope you will keep Red Hat updated with your experiences and successes
with Red Hat Enterprise Linux.
Please feel free to contact us with ideas and suggestions as to ways
we can enhance our Red Hat Enterprise Linux training and certification
programs at
https://www.redhat.com/training/certification/comments.html
Thank you very much for your interest in Red Hat Enterprise Linux!
Red Hat Certification Central
請問?
現在還會得到T-恤嗎!?
我超想要的@0@
« 上次編輯: 2010-12-12 21:51 由 fallloveinmy »
回覆: RHCE考過後,最想要的東西..
« 回覆 #1 於: 2010-12-07 09:29 »
我有一件二手穿過洗到快掉色的你要不要?!  ^_^
xiang
  • 文章數: 712
« 回覆 #2 於: 2010-12-07 12:39 »
netman 穿過的耶(羞
« 回覆 #3 於: 2010-12-07 13:52 »
netman 穿過的耶(羞
恩恩,原味的話更貴哦! ;D ;D
kenduest
  • 文章數: 3675
    • http://kenduest.sayya.org
« 回覆 #4 於: 2010-12-07 14:41 »
O_O
2002 年我好像送人了,結果對方現在都沒穿過, 哈哈。
I am kenduest - 小州
my website: http://kenduest.sayya.org/
fallloveinmy
  • 文章數: 4
« 回覆 #5 於: 2010-12-07 17:53 »
netman 穿過的耶(羞
恩恩,原味的話更貴哦! ;D ;D
沒關係,原味的話,您自已留著吧  ;D
廉價勞工
  • 文章數: 213
« 回覆 #6 於: 2010-12-09 11:20 »
圖片打了馬賽克 , 結果檔名忘了打... ;D
錢少、事多、離家遠…
位低、權輕、責任重…
kenduest
  • 文章數: 3675
« 回覆 #7 於: 2010-12-09 19:48 »
剛看一下檔名的名字,我監考的班級 XD
I am kenduest - 小州
fallloveinmy
  • 文章數: 4
« 回覆 #8 於: 2010-12-12 21:51 »
謝謝提醒@0@
fallloveinmy
  • 文章數: 4
« 回覆 #9 於: 2010-12-12 21:52 »
剛看一下檔名的名字,我監考的班級 XD
是阿^^
mtchang
  • 文章數: 5
    • http://mtchangtw.blogspot.com
« 回覆 #10 於: 2011-03-06 10:18 »
請問?
現在還會得到T-恤嗎!?
我超想要的@0@
但你有資格可以上 RH 網站買原廠 T-shirt
https://www.redhat.com/certification/
線上購買
http://redhat.brandfuelstores.com/?cPath=36
另外rh
有個 rhc{t,e,x,a} 認證論壇 裡面有很多同好可以討論
https://certforums.redhat.com/login.php
用你的 rhce 證書編號登入
dig-dig
Re: RHCE考過後,最想要的東西..
« 回覆 #11 於: 2014-01-12 15:35 »
終於在12月6號
Dear XXXXXXXXX:
programs at
請問?
現在還會得到T-恤嗎!?
我超想要的@0@
