作者 主題: Squid error  (閱讀 6257 次)
  • 酷學園旁聽生
  • 文章數: 5607
Squid error
« 於: 2001-10-08 23:10 »
Hi all,
不知為個squid出這些error:
(i use /etc/rc.d/init.d/squid status)to check it:
squid is stopped
squid:ERROR:No running copy
另外果個squid開啟後就不能stop,但它並沒有運作...........
(i use /etc/rc.d/init.d/squid restart)
squid stop             fail
squid start             ok
(use /etc/rc.d/init.d/squid status) to check:
squid is running
個squid.conf是我由另一部機試過沒有問題才copy過去的...........
但到了部真proxy就死了不動,真頭痛..................
  • 酷學園旁聽生
  • 文章數: 5607
Squid error
« 回覆 #1 於: 2001-10-09 03:04 »
1. check the error log
2. if you copy from other machine. make sure you have all dir and files in new machine.
(such like on your old machine, you put log on /var/log/squid/mylog/squid, but under new machine, you forget to make dir "mylog" under squid. it could cause problem)
3. post the error message, it's usually under /var/log/squid
GC
  • 酷學園旁聽生
  • 文章數: 5607
Squid error
« 回覆 #2 於: 2001-10-09 19:50 »
找到答案了,是因有些file set 了permission,squid 不能access 到,所以死了......
經過測試.應該是/usr/sbin/squid , /etc/某些file , /var/log/squid ........
但卻出了另一個問題,就是就執行squid , CPU的usage就直升上97%,又不知那裏出了問題了..............
Anonymous
  • 訪客
Squid error
« 回覆 #3 於: 2001-10-09 22:59 »
top 命令告訴您哪些命令最佔 cpu 呢﹖
  • 酷學園旁聽生
  • 文章數: 5607
Squid error
« 回覆 #4 於: 2001-10-10 18:22 »
squid 佔 97%.
在不斷嘗試下,終於找到原因,要把 /dev 的 permission set做 755.
但想請問為何部NAT+Squid+Packet Filter不斷跳出 NET:2 messages suppress
的訊息...................
這是/var/log/messages的其中一part,請指點一下小弟吧.
squid[2169] : squid Parent :child process 2170 started
(squid)       : getpwnam fail to find userid for effective user 'squid'
squid[2169] : squid Parent :child process 2170 exited with status 0
squid[2169] : squid Parent :child process 2248 started
kernel : eth0 :setting full-duplex based on MII #24 link partner capability of 45el
kernel : NET :2 messages suppressed
kernel : NET :1 messages suppressed
kernel : NET :8 messages suppressed
kernel : NET :3 messages suppressed
kernel : NET :9 messages suppressed
last messages repeated 2 times
Remark:
Redhat 7.1
kernel 2.4.2
eth0是對內的Lan card (3c905)
eth1沒有用
eth2是對外的Lan card (intel lan card)
Thanks
Anonymous
  • 訪客
Squid error
« 回覆 #5 於: 2001-10-10 21:30 »
還怪﹐我暫時沒什麼建議。
  • 酷學園旁聽生
  • 文章數: 5607
Squid error
« 回覆 #6 於: 2001-10-10 23:58 »
不打緊.個NAT還沒出現大問題.
還在到處找答案.....haha
kev_renee1
  • 文章數: 47
Squid error
« 回覆 #7 於: 2002-05-18 22:04 »
插花一下!請問一下您找到原因了嗎!因為我也有碰到這個問題..........
另請教/etc/某些file------------->是哪些???
而/dev下面又是那些呢...............
感謝^.^
