作者 主題: Yeeh~ 我今天收到紅帽電郵 通過RHCE 考試了~~~  (閱讀 29470 次)
wst2080
  • 文章數: 93
  • 阿胖資研-鴨鴨
這是我今天早上收到的電郵~~~~
The results of your RHCE Certification Exam are reported below. The RHCE Certification Exam allows candidates to qualify for the Red Hat Certified Engineer (RHCE) and Red Hat Certified Technician (RHCT) certificates. Please note that the RHCE designation is understood to both include and supersede the RHCT designation.
SECTION I: TROUBLESHOOTING AND SYSTEM MAINTENANCE
RHCE requirements: completion of compulsory items (50 points)
overall section score of 80 or higher
RHCT requirements: completion of compulsory items (50 points)
Compulsory Section I score: 50.0
Non-compulsory Section I score: 50.0
Overall Section I score: 100
SECTION II: INSTALLATION AND CONFIGURATION
RHCE requirements: score of 70 or higher on RHCT components (100 points)
score of 70 or higher on RHCE components (100 points)
RHCT requirement: score of 70 or higher on RHCT components (100 points)
RHCT components score: 93.5
RHCE components score: 96.4
RHCE Certification: PASS
Congratulations -- you are now certified as a Red Hat Certified Engineer! Your RHCE Certificate number is 8050093xxxxxxxx. The attached file is your personal print-ready certificate.
You are entitled to print this document and use it to demonstrate that you are an RHCE, provided you remain an RHCE in good standing. You may not modify or change the document's contents in any way, nor
may you appropriate any elements of this document for use in other electronic documents or printed materials. You may only print the document in its entirety. Any other use of the document must be approved by Red Hat, Inc.
----- 上個月考試只差10就考到RHCE了說,不過有個安慰獎~~~ RHCT...
這次就更加努力的準備一個月,來加強考試的熟悉程度與操作方面~~~
只要熟練~~~ 早上的部份差不多一個小時內都可以完成 (包含PhaseA and B)
下午的部份差不多兩個小時內就可以搞定 (包含系統安裝與組態設定等)
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
這陣子的努力 總算不是白費了
----------這是上個月考試的成績--------------------------------------
Non-compulsory Section I score: 20.0
Overall Section I score: 70
RHCT components score: 74.1%
RHCE components score: 80.0%
RHCT Certification: PASS
RHCE Certification: NO PASS
« 上次編輯: 2009-04-19 13:30 由 wst2080 »
wst2080
  • 文章數: 93
  • 阿胖資研-鴨鴨
考RHCE的準備書籍~~~
眼觀千萬行 過目隨即忘
沒辦法... 誰叫我是揮發性記憶體阿!~~~
 :o :o :o :o :o :o :o :o :o :o :o :o :o :o
我準備的書籍
« 上次編輯: 2009-04-19 13:41 由 wst2080 »
otsdog
版兄的書會不會太多了
這麼用心準備
不負苦心人阿
恭喜您囉
jaymsa
  • 文章數: 409
    • Jay's Blog
這是我今天早上收到的電郵~~~~
這陣子的努力 總算不是白費了
哇...恭喜恭喜!!
分數很高喔~~
歡迎加入RHCE.....可以互相學習喔!!
Linux真好玩...博大精深!!
RHCE,ISO27001,ISO20000
http://jayclub.no-ip.org/jayblog
owen_lu
  • 文章數: 5
考RHCE的準備書籍~~~
眼觀千萬行 過目隨即忘
這麼多書,真厲害
記得當初我去考的時候只有看鳥哥的二本書,還有您照片中最右邊那本書而已
不過我平常就有在管理 Linux Server,所以看那些書其實也只是在複習
( 當時是 RHCE 滿分 PASS :p )
xiang
  • 文章數: 712
恭喜大大考過了~~~~
不過你證書的編號要不要也塗掉比較好阿.....
wst2080
  • 文章數: 93
  • 阿胖資研-鴨鴨
恭喜大大考過了~~~~
有~~~ 我塗掉一半了~~~  ;D ;D ;D ;D ;D
littleq0903
  • 文章數: 11
為什麼你的書有重複阿XD?
jsxiaobai
  • 考題在手,考試無憂
    • 51-Pass題庫網
可否分享RHCE學習書籍或者練習試題?
Email:jsxiaobai@yahoo.com.tw
各類認證考試資訊,請訪問我的部落格http://blog.itcert.org
wst2080
  • 文章數: 93
  • 阿胖資研-鴨鴨
為什麼你的書有重複阿XD?
一個是 書房讀物 ; 另外一個是 廁所讀物 (就算拉屎,也要多工)
wst2080
  • 文章數: 93
  • 阿胖資研-鴨鴨
可否分享RHCE學習書籍或者練習試題?
RHCE的課本LAB做到爛掉... 通常就有八成的把握了!!!
