作者 主題: [心得分享] OpenVPN 建置方案  (閱讀 94261 次)
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 於: 2005-09-12 20:37 »
http://www.study-area.org/tips/openvpn.html
一, 功能介紹
* SSL vpn 方案
* 可完整支援 L2 及 L3 連線
* 使用 CA 簽章確?#123;及?#91;密, ?#93;可使用單一鍵值對稱?#91;密
* 同時支援 Linux, FreeBSD, OS X 與 Windows
* 支援 tunnel 及 TAP 連線方式
* GPL 授權方式
二, 實作環境
2.1 server
   OS:    CentOS 4.1 Linux
   real IP:   192.168.100.151
   vpn IP:   10.8.0.1
2.2 client
   OS:   Windows XP(home)
   real IP:   192.168.100.x(dhcp)
   vpn IP:   10.8.0.x(server assigned)
三, 安裝
3.1 server
# 安裝 lzo (source rpm)
rpmbuild --rebuild http://openvpn.net/release/lzo-1.08-4.rf.src.rpm
rpm -ivh /usr/src/redhat/RPMS/i386/lzo-*.rpm
# 安裝 openvpn
mkdir /usr/src/pkgs
cd /usr/src/pkgs
wget http://openvpn.net/release/openvpn-2.0.2.tar.gz
rpmbuild -tb openvpn-2.0.2.tar.gz
rpm -ivh  /usr/src/redhat/RPMS/i386/openvpn-2.0.2-1.i386.rpm
# 複制?#93;定範例
cp -r /usr/share/doc/openvpn-2.0.2/easy-rsa/ /etc/openvpn/
cp /usr/share/doc/openvpn-2.0.2/sample-config-files/server.conf /etc/openvpn/
# ?#93;定 CA 環境
cd /etc/openvpn/easy-rsa/
vi vars
   export KEY_COUNTRY=TW
   export KEY_PROVINCE=Taiwan
   export KEY_CITY=Tainan
   export KEY_ORG="Study-Area"
   export KEY_EMAIL="netman@study-area.org"
. ./vars
./clean-all
# 建置 root CA
./build-ca
   Generating a 1024 bit RSA private key
   writing new private key to 'ca.key'
   You are about to be asked to enter information that will be incorporated
   into your certificate request.
   What you are about to enter is what is called a Distinguished Name or a DN.
   There are quite a few fields but you can leave some blank
   For some fields there will be a default value,
   If you enter '.', the field will be left blank.
   Country Name (2 letter code) [TW]:
   State or Province Name (full name) [Taiwan]:
   Locality Name (eg, city) [Tainan]:
   Organization Name (eg, company) [Study-Area]:
   Organizational Unit Name (eg, section) []:test
   Common Name (eg, your name or your server's hostname) []:CA
   Email Address [netman@study-area.org]:
# 建置 server key 及 crt
./build-key-server ovpnsrv1
   writing new private key to 'ovpnsrv1.key'
   Common Name (eg, your name or your server's hostname) []:ovpnsrv1
   Please enter the following 'extra' attributes
   to be sent with your certificate request
   A challenge password []:
   An optional company name []:
   Using configuration from /etc/openvpn/easy-rsa/openssl.cnf
   Check that the request matches the signature
   Signature ok
   The Subject's Distinguished Name is as follows
   countryName           :PRINTABLE:'TW'
   stateOrProvinceName   :PRINTABLE:'Taiwan'
   localityName          :PRINTABLE:'Tainan'
   organizationName      :PRINTABLE:'Study-Area'
   organizationalUnitName:PRINTABLE:'test'
   commonName            :PRINTABLE:'ovpnsrv1'
   emailAddress          :IA5STRING:'netman@study-area.org'
   Certificate is to be certified until Sep  7 20:36:58 2015 GMT (3650 days)
   Sign the certificate? [y/n]:y
   1 out of 1 certificate requests certified, commit? [y/n]y
   Write out database with 1 new entries
   Data Base Updated
# 建置 Diffie Hellman 參數
./build-dh
   Generating DH parameters, 1024 bit long safe prime, generator 2
   This is going to take a long time
# 安裝 server 所需的 CA 文件
cp keys/ca.crt ../
cp keys/dh1024.pem ../
cp keys/ovpnsrv1.key ../
cp keys/ovpnsrv1.crt ../
# 配置 server ?#93;定檔(沒提及的請保持原樣)
cd ../
vi server.conf
   dev tap
   ;dev tun
   ca ca.crt
   cert ovpnsrv1.crt
   key ovpnsrv1.key  # This file should be kept secret
# 啟動 server
service openvpn restart
chkconfig openvpn on
3.2 Client
# 下載並安裝 openvpn (GUI 版本)
http://openvpn.se/files/install_packages/openvpn-2.0.2-gui-1.0.3-install.exe
# ?#93;定環境
cmd.exe
cd "c:\Program Files\OpenVPN\easy-rsa"
copy openssl.cnf.sample openssl.cnf
copy vars.bat.sample vars.bat
edit vars.bat
   (內容必需與 server 一至, 尤其 KEY_ORG 項目.)
# 建置 CA環境
vars
# 建置 client key 與 crs
build-key ovpnclt1
   Common Name (eg, your name or your server's hostname) []:ovpnclt1
# 提交 crs (請使用安全方式, 本例用 pscp.exe .)
pscp keys/ovpnclt1.csr root@192.168.100.151:/etc/openvpn/easy-rsa/keys
# 轉至 server, 簽署 client crt
./sign-req ovpnclt1
   Signature ok
   commonName            :PRINTABLE:'ovpnclt1'
   Certificate is to be certified until Sep  7 21:07:33 2015 GMT (3650 days)
   Data Base Updated
# 安裝 CA 文件
cd ..\config
pscp root@192.168.100.151:/etc/openvpn/easy-rsa/keys/ovpnclt1.crt  .\
pscp root@192.168.100.151:/etc/openvpn/easy-rsa/keys/ca.crt  .\
copy ..\easy-rsa\keys\ovpnclt1.key .\
# 複制 sample ?#93;定檔:
copy ..\sample-config\client.ovpn .\
# 配置 client 端?#93;定檔
右下角(OpenVPN GUI)
右鍵--> Edit Config (沒提及的, 請保持原貌)
   dev tap
   ;dev tun
   dev-node OpenVPN_Tap
   remote 192.168.100.151 1194
   ca ca.crt
   cert ovpnclt1.crt
   key ovpnclt1.key
   ns-cert-type server
# ?#93;定 openvpn TAP 界面
控制台-->網路連線-->TAP-Win32#(#)
右鍵-->重新命名-->OpenVPN_Tap
# 啟動 openvpn client
右下角(OpenVPN GUI)
右鍵--> Connect
# 測試
ping 10.8.0.1
四, 注意:
4.1 要允許多個 client 相互連線, 須在 server 端打?#125;:
client-to-client
4.2 若想隱藏 server IP, 但純作 bridge 來用:
;server 10.3.0.0 255.255.255.0
server-bridge 10.8.0.1 255.255.255.0 10.8.0.129 10.8.0.246
4.3 若由其它 CA 建的 csr , Organization(KEY_ORG=)必需要一至.
否則, 不能簽署.
4.4 CA 文件分佈:
   server:
      ca.crt
      dh.pem
      dh1024.pem
      server.crt
      server.key   # 必須保密
   client:
      ca.crt
      client.crt
      client.key      # 必須保密
   CA server:
      ca.key      # 必須保密
4.5 Windows XP + SP2 與某些安全套件一併運行可能會導至 windows client 端不能成功.
目前除了移除 SP2 或衝突套件外, 暫無更好方法.
參考: http://openvpn.se/xpsp2_problem.html
五, 官方網站及文件:
http://openvpn.net/
http://openvpn.net/howto.html
« 上次編輯: 2008-12-27 01:19 由 netman »
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #1 於: 2005-09-12 22:40 »
報告! rpmbuild -tb openvpn-1.6.0.tar.gz  應該是 rpmbuild -tb openvpn-2.0.2.tar.gz 之誤! ^_^
我也貼一下 mdk2005 openvpn-1.6.0-2mdk 的設定(還沒有試成功)
    # /etc/openvpn/client.conf
    # 本機 client 端
    # client (加上這一行,會發生 Unrecognized option or missing parameter(s) in client.conf:2: client ) :(
    dev tun
    proto udp
    # 遠端 server 主機的 ip & 連接 port
    remote 61.218.xxx.xxx 1194
    resolv-retry infinite
    nobind
    user nobody
    group nobody
    persist-key
    persist-tun
    tls-client
    ca ca.crt
    cert client1.crt
    key client1.key
    tls-auth ta.key 1
    # ns-cert-type server (一樣的錯誤 Unrecognized option or missing parameter(s) in client.conf:23: ns-cert-type)
    comp-lzo
    verb 3
mark 掉那兩行後
service openvpn start
可以看到成功的訊息
    openvpn[25442]: OpenVPN 1.6.0 i586-mandrake-linux-gnu
[SSL] [LZO] [PTHREAD] built on Jan 13 2005
openvpn[25442]: Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
openvpn[25442]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
openvpn[25442]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
openvpn[25442]: LZO compression initialized
openvpn[25442]: Control Channel MTU parms [ L:1342 D:166 EF:66 EB:0 ET:0 EL:0 ]
openvpn[25442]: TUN/TAP device tun0 opened
openvpn[25442]: Data Channel MTU parms [ L:1342 D:1342 EF:42 EB:19 ET:0 EL:0 ]
openvpn[25442]: Local Options hash (VER=V3): '4eb33a0f'
openvpn[25442]: Expected Remote Options hash (VER=V3): '8fcf9375'
openvpn[25445]: GID set to nobody
openvpn[25445]: UID set to nobody
openvpn[25445]: PTHREAD support initialized
openvpn[25445]: UDPv4 link local: [undef]
openvpn[25445]: UDPv4 link remote: 61.218.xxx.xxx:5000
openvpn:  succeeded[/list]
查詢 ifconfig 並沒有出現 tun0 的介面?
port 5000 似乎也不對?
到這裡傷腦筋中...
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #2 於: 2005-09-13 00:01 »
dev 必須是 tun 或 tap 兩者之一, 不能沒有, 且 server 與 client 要一至.
tun 效果較好, 也比較簡單. 但要是你要弄較複雜的環境, 才選 tap .
至於 ns-cert-type server, 是較嚴謹的設定, 以防 man-in-the-meddle 的欺騙.
CA 的關鍵在於:
1) 要用相同的 ORG
2) 交給同一 root CA 簽署
3) key 與 crt 要一至.
4) ca.crt 要在 client 與 server 兩端要一至
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #3 於: 2005-09-13 07:34 »
會出現 port 5000 應該是這個原因
IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA.  OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
還有發生 Unrecognized option or missing parameter(s) 是因為版本的問題
從 1.6.0 升級到 2.0.2 就不會出現了。^_^
雖然還是有出現"成功"的訊息,但是 client 端的 tun0 還是沒有出現?
再找! :)
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #4 於: 2005-09-13 09:14 »
兩邊都是 linux 嗎?
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #5 於: 2005-09-14 09:23 »
是的!
server 端是 kernel 2.4.18 redhat ,openvpn 版本
openvpn --version
OpenVPN 2.0 i386-redhat-linux [SSL] [LZO] built on Apr 30 2005
Developed by James Yonan
設定組態檔(已經把解說去掉!)
cat /etc/openvpn/server.conf
local 61.218.xxx.xxx
port 1194
proto udp
dev tun
tls-server
ca ca.crt
cert server.crt
key server.key  # This file should be kept secret
dh dh1024.pem
server 192.168.2.0 255.255.255.0
ifconfig-pool-persist ipp.txt
push "route 192.168.0.0 255.255.255.0"
push "redirect-gateway"
client-to-client
keepalive 10 120
tls-auth ta.key 0 # This file is secret
comp-lzo
max-clients 10
user nobody
group nobody
persist-key
persist-tun
status openvpn-status.log
verb 3
成功的訊息! (ifconfig 有出現 tun0 的虛擬設備,netstat 有監聽 udp 1194)
openvpn[22353]: OpenVPN 2.0 i386-redhat-linux [SSL] [LZO] built on Apr 30 2005
openvpn[22353]: Diffie-Hellman initialized with 1024 bit key openvpn[22353]: Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
openvpn[22353]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
openvpn[22353]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
openvpn[22353]: TLS-Auth MTU parms [ L:1542 D:166 EF:66 EB:0 ET:0 EL:0 ]
openvpn[22353]: TUN/TAP device tun0 opened
openvpn[22353]: /sbin/ip link set dev tun0 up mtu 1500
openvpn[22353]: /sbin/ip addr add dev tun0 local 192.168.2.1 peer 192.168.2.2
openvpn[22353]: /sbin/ip route add 192.168.2.0/24 via 192.168.2.2
/etc/hotplug/net.agent: invoke ifup tun0
openvpn[22353]: Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:23 ET:0 EL:0 AF:3/1 ]
openvpn:  succeeded
openvpn[22372]: GID set to nobody
openvpn[22372]: UID set to nobody
openvpn[22372]: UDPv4 link local (bound): 61.218.xxx.xxx:1194
openvpn[22372]: UDPv4 link remote: [undef]
openvpn[22372]: MULTI: multi_init called, r=256 v=256
openvpn[22372]: IFCONFIG POOL: base=192.168.2.4 size=62
openvpn[22372]: IFCONFIG POOL LIST
openvpn[22372]: Initialization Sequence Completed
client 端 kernel 2.6.11-6mdk mdk2005,openvpn
OpenVPN 2.0.2 i586-mandrake-linux-gnu [SSL] [LZO] [EPOLL] built on Sep 13 2005
N 老大想玩嗎? ^_^
不只把 VPN 架起來而已喔! 真的玩下去,要出現"綠色 Sign On 晝面"才算完成! :lol:
想玩的話,我再把相關資料給您! ^_^
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #6 於: 2005-09-14 13:29 »
好啊, 給我玩玩看?
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #7 於: 2005-09-15 23:02 »
那個xp sp2的問題,現在有得解嗎?!
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #8 於: 2005-09-16 02:37 »
引述: "duncanlo"
沒解, 我給的 link 你可看看.
不過, 在我的 IBM notebook 上, 也是 xp + sp2 , 確沒問題.
但我老婆的機器卻不行...  >_<
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #9 於: 2005-09-16 12:34 »
引述: "netman"
引述: "duncanlo"
沒解, 我給的 link 你可看看.
但我老婆的機器卻不行...  >_<
老外說用2.0 beta版可以用說,
你要不要先check一下已安裝的版本差異!!
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #10 於: 2005-09-16 14:26 »
嗯, 我沒 try 過 2.0-beta .
不過 openvpn 的 FAQ 跟 mail-list 上, 是各個版本都有這問題.
我之前試 1.6.0 時, xp to xp 也是 okay 的.
因此不確定問題在哪?
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #11 於: 2005-09-23 02:42 »
為了這個 XP+SP2,
我剛才重新灌了一台, 怪! 測起來沒問題!..........  >_<
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #12 於: 2005-09-23 13:06 »
我剛才想到另外一個問題,
像PPTP的VPN,
client端的網路環境,
若有firewall時,
必須要有支持pptp的相關設定才行,
那用openvpn的方式也需要配合的嗎?!
來去試一下...
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #13 於: 2005-09-23 13:23 »
引述: "duncanlo"
來去試一下...
應該要吧?
iptables -A INPUT -i tun+ -p udp -j ACCEPT
jimes007
  • 文章數: 12
[心得分享] OpenVPN 建置方案
« 回覆 #14 於: 2005-09-23 14:48 »
請問一下,在 windows 環境下,是否需要先安裝其他的軟體?
在執行 build-key ovpnclt1 時會出現一些錯誤訊息如下。
C:\PROGRA~1\OpenVPN\easy-rsa>build-key.bat opvnclt1
error on line -1 of openssl.cnf
2824:error:02001002:system library:fopen:No such file or directory:crypto/bio/bs
s_file.c:104:fopen('openssl.cnf','rb')
2824:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c
:107:
2824:error:0E064072:configuration file routines:CONF_load:no such file:crypto/co
nf/conf_def.c:197:
Using configuration from openssl.cnf
error loading the config file 'openssl.cnf'
2736:error:02001002:system library:fopen:No such file or directory:crypto/bio/bs
2736:error:2006D080:BIO routines:BIO_new_file:no such file:crypto/bio/bss_file.c
:107:
2736:error:0E064072:configuration file routines:CONF_load:no such file:crypto/co
nf/conf_def.c:197:
The system cannot find the file specified.
感覺好像要先裝 openssl 的樣子,不知是不是這樣子。
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #15 於: 2005-09-23 16:11 »
引述: "duncanlo"
我剛才想到另外一個問題,
像PPTP的VPN,
client端的網路環境,
若有firewall時,
必須要有支持pptp的相關設定才行,
來去試一下...
要是指 XP firewall 的話, 就算全關了還是一樣.
目前我不确定老婆的電腦是啥原因不行, 之前1.6版本時還是可以的.
昨晚灌的 XP, 在裝 SP2 之前跟之後的測試都是 OK 的...
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #16 於: 2005-09-23 16:25 »
to jimes007:
你的 error 我沒有碰到呢...
不知你的版本是甚麼?
目前 openvpn 只能在 w2k 跟 xp 上跑....
jimes007
  • 文章數: 12
[心得分享] OpenVPN 建置方案
« 回覆 #17 於: 2005-09-23 17:10 »
Netman前輩,小弟的是XP pro SP2,內建的firewall未開。
主要是訊息中有缺檔案的樣子,例如像 No such file or directory:crypto/bio/bs
s_file.c。
jimes007
  • 文章數: 12
[心得分享] OpenVPN 建置方案
« 回覆 #18 於: 2005-09-23 20:28 »
補充:
在 easy-rsa 目錄下看到 README.txt,依照其方式再輔以您的設定已完成設定,可以連上 server 端。
目前最新的問題是,server IP 10.8.0.1,client IP 分到 10.8.0.2,由 server 端可以 ping client OK,但是 client 無法 ping server,還找不到問題所在。
請問 Netman 前輩,可有方法指點一下,謝謝。
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #19 於: 2005-09-23 20:57 »
引述: "jou"
引述: "duncanlo"
來去試一下...
應該要吧?
這個我看不懂啦...
是要轉什麼port還是protocol才行?!
(其實我也還沒研究說...)
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #20 於: 2005-09-23 21:38 »
server 能夠 ping client, 那就 okay 了.
client 不能 ping server, 可能是 server 的 firewall 關係? 你關一關看?
jimes007
  • 文章數: 12
[心得分享] OpenVPN 建置方案
« 回覆 #21 於: 2005-09-24 01:37 »
因為區網(192.168.2.x)可以通,所以想到以前實驗 NAT 時有對 iptable 做一些設定,最後的結果是 iptable 設定的問題。
目前將 iptables 關掉,因為 server 是放在 IP 分享器的後面,事實上不太用得到 iptables 的功能。
感謝 Netman 前輩的指導。
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #22 於: 2005-09-25 12:53 »
用起來真是讚...(我NB上的GUI Status字超小的,都要另外看Log)
不過明天上班後,才能從外面作實機測試...
openvpn x86 gui想要中文化,
只要修改source內的.rc檔,
有人有現成的嗎?!
  • 文章數: 17478
[心得分享] OpenVPN 建置方案
« 回覆 #23 於: 2005-09-25 18:53 »
是啊... 那個 status 視窗是擺好看的...  >_<
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #24 於: 2005-09-25 20:26 »
引述: "duncanlo"
引述: "jou"
引述: "duncanlo"
來去試一下...
應該要吧?
這個我看不懂啦...
(其實我也還沒研究說...)
我看到有一個UDP 1194 port,
是這個嗎?!
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #25 於: 2005-09-25 20:30 »
引述: "netman"
感覺起來,已經進步粉多了...
今天花了一點時間看了一下.rc檔的內容,
很多地方,還真不知道如何翻成中文,
我想它也沒什麼功能或選單的英文很難,
所以大家就繼續看小icon的狀況就夠了...
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #26 於: 2005-09-26 08:16 »
引述: "duncanlo"
引述: "duncanlo"
引述: "jou"
引述: "duncanlo"
來去試一下...
應該要吧?
這個我看不懂啦...
(其實我也還沒研究說...)
是這個嗎?!
如果是開 tun 的設備且 proto 是用 udp 就可以開上面的規則。
是的! 看您在 server or client .conf 裡的設定值怎麼設?
在 1.6.0 時的預設監聽 port 是 5000 ,2.0 以後開成 port 1194 了。
所以...如果您是 proto 是用 udp ,dev 是用 tun (成功時,可用 ifconfig 看到 tun0 監聽)
您就可以利用上述的 iptables 規則,讓封包 accept 進來! ^_^
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #27 於: 2005-09-26 08:59 »
引述: "jou"
引述: "duncanlo"
引述: "duncanlo"
引述: "jou"
引述: "duncanlo"
來去試一下...
應該要吧?
這個我看不懂啦...
(其實我也還沒研究說...)
是這個嗎?!
jou前輩這樣解釋我就聽的懂了...
不過小弟公司比較窮,只用的起pix,
先來試試看client通不通,
真不通再請同事幫我處理NAT轉到內部的問題...
duncanlo
  • 文章數: 7312
[心得分享] OpenVPN 建置方案
« 回覆 #28 於: 2005-09-26 11:01 »
真是讚!!!
我只修改了一點server.conf的內容,
把dns的設定加上去而已...
jou
  • 文章數: 4989
[心得分享] OpenVPN 建置方案
« 回覆 #29 於: 2005-09-28 14:33 »
曾經發生以下的訊息,記綠下來好了。
TLS errors
TLS Error: TLS key negotiation failed to occur within 60 seconds.
TLS Error: TLS handshake failed
This could mean your packets are being blocked by a firewall, your certificates on both ends don't match, or the IPs or subnet masks are wrong in your config files.
我發生的是 firewall 的問題。
-A INPUT -s 61.218.xxx.xxx -p tcp -m tcp --dport 1194 -j ACCEPT
-A INPUT -s 61.218.xxx.xxx -p udp -m udp --dport 1194 -j ACCEPT
在伺服器端的防火牆設定。
如果過不了,您可能會在 client 端的 /var/log/messages 發現如上的錯誤訊息。
