作者 主題: debug the program or webpage in other pc  (閱讀 3058 次)
小徒兒
  • 文章數: 622
« 於: 2005-06-18 20:40 »
1. change the Web.config
    <compilation
         defaultLanguage="c#"
         debug="true" />
  #the debug must be true
  #all the asp project are packed into .dll, so there will be one process to be the start running point, which is w3wp.exe (IIS 6.0) or aspnet_wp.exe (IIS 5.0)
2. you can debug the others' computer .net windows program or web application.
open the source code project/偵錯/處理序:
名稱: [key in the computer name or ip, if the computer is over internet, you need to open the port of RPC and DCOM]
[ v ]顯示系統處理序
select [w3wp.exe]
[ v ] 附加
3. if you want to trace or debug the program or web pages over internet,pls refer to
http://msdn.microsoft.com/library/CHT/vsdebug/html/vctskInstallingRemoteDebugMonitor.asp
