作者 主題: 請問我的電腦是否給入侵?  (閱讀 4049 次)
linuxcoke
  • 文章數: 34
請問我的電腦是否給入侵?
« 於: 2004-01-18 17:23 »
我用的是windows pro 2000,
近日在賽門鐵克網站, 用free virus scan,
report 沒有virus,
但port 1025 給打開了, report這是unuse port.
還有每次start computer,c driver 總是給設定成 file sharing, 而不能關閉此功能.
各位大大, 我是否給控制了!
如不想重灌, 如何入手.
Thank you so much.
  • 文章數: 8830
請問我的電腦是否給入侵?
« 回覆 #1 於: 2004-01-18 17:40 »
恩..... 你被木馬程式給入侵了........
建議立刻使用防火牆+網路通訊監督軟體, 以免變成另外一個散播中心......
linuxcoke
  • 文章數: 34
help me !!!!!!!!!!!!!!!!!!!!!!!
« 回覆 #2 於: 2004-01-19 18:33 »
reinstall windows 2000 pro,
還有virus,
C:\WINNT\system32\down.com is infected with W32.HLLW.Raleka
C:\WINNT\system32\ntrootkit.exe is infected with Backdoor.Rtkit
C:\WINNT\system32\svchost32.exe is infected with W32.HLLW.Raleka
C:\WINNT\system\svchost.exe is infected with W32.HLLW.Raleka
C:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\Q567CLM5\ntrootkit[1].exe is infected with Backdoor.Rtkit
C:\Documents and Settings\Default User\Local Settings\Temporary Internet Files\Content.IE5\CHQ3CXIB\svchost[1].exe is infected with W32.HLLW.Raleka
linuxcoke
  • 文章數: 34
我已重灌了4次,救命啊!!!!!!!!!!!!!
« 回覆 #3 於: 2004-01-19 18:44 »
我用的是"大學OEM version",
過往一直用,都沒有問題,還經到microsoft web site update,
近期才經常出事.
快瘋了............................
linuxcoke
  • 文章數: 34
我是否要give up windows product ?
« 回覆 #4 於: 2004-01-19 18:53 »
我已安裝Norton Antivirus software,仍然如是.
轉用linux是不是唯一方法 ?
linuxcoke
  • 文章數: 34
剛完成了.
« 回覆 #5 於: 2004-01-19 20:08 »
真是給Norton  Antivirus software氣壞.
竟不能delete virus.
要手動delete.
方法如下:
. Reversing the changes made to the registry
CAUTION: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified keys only. Read the document, "How to make a backup of the Windows registry," for instructions.
Click Start, and then click Run. (The Run dialog box appears.)
Type regedit
Then click OK. (The Registry Editor opens.)
Delete the keys:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Rtkit
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NPF
Exit the Registry Editor.
